showinfo="false" not working
www.techwritersbureau.com
Hi, I have the configuration set to show the info bar. I have a text widget in the left column using the shortcode
[tribulant_slideshow gallery_id="1" showinfo="false" resheight="40" resheighttype="%"]
but it still shows the info bar. Is there another argument I need in order to to get it to stop showing?
Thank you for your message.
It's currently not a known issue.
Are you using the latest version of the plugin?
Can you add the shortcode in a page or post and let me know if it's still not working?
Which plugin do you use to show shortcodes in text widgets?
