[SOLVED] Shipping per product
I currently have 2 shipping rates for user to choose from. One for within Australia and the other for international orders (this is not automatic - users have to choose which one they require).
I need to make the shipping rates apply pre product rather than per order. Eg each product will cost $8 to post in Australia and $20 internationally.
I can't see a way to apply a per product postage charge? Is this possible?
Thanks for your reply. Here goes:
First you create your two shipping methods, Australia Post Local and Australia Post International, under Checkout > Shipping Methods, but zero price them (0.00):
http://screencast.com/t/1hcIJ5fi
http://screencast.com/t/nCKfSeAlh
Then edit your product, and under product pricing and shipping edit the settings as in the following screenshot:
http://screencast.com/t/dyYJvK3oDjc
If you follow this method you should have the desired effect.
May I ask why you want this on a per product basis though? Will there be only certain products that this will apply to? If it will be the majority of products, it might be worth while having this as a global setting, making the selection automatic, and then just making other products the exception to the rule?
All the products are intangible except for the one physical book so thats why this was only relevant to one product. All other products didnt have shipping. In the future their may be more books and these would also follow the same rule.
Thanks, this solution worked!
[Solved]
You're right, this should work well for your client.
I must just mention though that if you did this globally and simply excluded the digital products from the global shipping calculation, then the choice between international or local shipping would have been made automatically, leaving no room for international "sharlatans" to select local shipping to save a few bucks :-)
Anyway, glad it worked! Please let us know if you encounter any hiccups along the way, we're always happy to help.
We have the feature whereby the variation options affect the total weight on our development list, and plan to add it in the near future.
I hope that helps?
