Order Processing Plugin?
edited April 2013 in General
We are looking for a plug in to pass information to our order processing system. Does anyone know of such a utility? We have a cart set up that sells merchandise ( T-shirts, Hats and other printed items) Our order fulfillment company would like to get the data from the sales electronically so they can go directly into the production software.
Thank you,
R
  • 2 Comments sorted by
    Hi ramartijr,
    We can't speak for the rest of the community, but we're unaware of such a plugin.
    Do you use our Shopping Cart plugin? If so, you could set your fulfilment company up as a "Supplier" under Checkout > Suppliers, and then assign them as supplier to every product they should ship. This is done under Save a Product > Additional Fields. They will then receive email notification of every order and be able to process it accordingly.
    Thank you Phil.. I wasnt expecting one. I think we can pull the info we need directly out of the database.
