active/inactive button
Here's an easy one.
On the Manage Products page, the words Active/Inactive should be a button to change states instead of actually having to open the specific product.
David
Here's an easy one.
David
Thanks for your post and for the suggestion.
There are Bulk Actions at the top of the list of products that you can use for that purpose, as you can see here:
http://screencast.com/t/IrfqJAOP
This also allows you to apply it to more than one product simultaneously.
I hope this helps, David?
