UPS API - How can I add a freight option? If an order goes over 150lb, i get an error.
There is configuration options and documentation info from UPS, but the api is already input into Tribulant, haw can i customize it or add a freight option?
We developed an extension plugin specifically for this purpose.
The UPS Freight was developed as an extension plugin since it is a separate API but it wasn't released yet.
You can pre-order it for $15 and we'll send you the extension to install and use immediately.
You will be added to our pre-order list so that the download can be added to your account upon release
If you want to proceed with this you can please open a new ticket under our helpdesk: http://www.tribulant.com/support so we can send the payment details.
Let us know if it helps ok?
