Change Variations default inventory/stock setting?
I have two Product Variations with multiple Variation Options. When I Bulk Action Set the variations to my products and add the variation options, everything works fine, except the Variation Options Inventory/Stock are defaulted to 0. I need them set to -1, as I am not using inventory. In order to set the variation options Inventory/Stock to -1, I have to go into each product. With a lot of products, this is not feasible and would have to be done anytime there is a change to the Variations or Variation Options, as it resets to 0 if you Set the variations.
Where is the code located which sets the default Inventory/Stock on Product Variation Options to 0? I need to change it, unless there is a way to do this through the plugin?
Thank you!
Thank you!
