[SOLVED] No image, no thumbnails, WP Multi
Hello, You can see that no image are loaded. I guess it's something with the path of the image folder, but I don't really understand previous posts on this forum about this issu.
I show a capture of what happen in the Manage Slides:
Thanks for all !
WP 3.4.2
A TimThumb error has occured
The following error(s) occured:- Could not find the internal image you specified.
Query String : src=wp-content/uploads/slideshow-gallery/bpsignentranceslide.jpg&w=600&h=400&q=100&a=tTimThumb version : 2.8.10
Also I can see there is no thumbnails in " Manage Slides" but when I click on the missing thumbnail, the original image appears on its window...
Thank you for your help and support, your forum is working good and the plugin looks fantastic, really want to use it !!
I'm just following up to find out if your issue had been resolved?
